Appearance Settings ?
  • Hi all,
    I am rather happy with the Raspad, unfortunately I changed the various appearance settings to make it look a bit "cooler" but now the click on the "x" to close a window is not working anymore...
    Any idea to set it back to basic settings or do I have to reinstall the OS?
    Many thanks !!!
    Greetings from Hamburg - Torsten
  • @Torsten Frenschkowski
    We have not encountered a similar problem. You can read this post which is similar: https://www.raspberrypi.org/forums/viewtopic.php?t=174953
    Or you can try to delete the configuration file, and then restart the Raspberry Pi to restore the default:
    rm -rf ~/.config/lxpanel/LXDE-pi
    sudo reboot
  • Hi RasPad Support,
    many thanks for your fast answer!
    I tried out your idea regarding the config file, but it didn't help.
    I reinstalled RasPad OS, now everything is fine again....
    cheers - Torsten
