Using RaspadOS. Upgraded from Debian 10 to Debian 11 and no lnoger have the ability to rotate the screen. The shim is detected:
sudo i2cdetect -y 1
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- 36 -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- --
but I think it's probably because the version of Python was upgraded? Here's the error I get on calibration:
sudo auto-rotator calibrate
Traceback (most recent call last):
File "/usr/local/bin/auto-rotator", line 6, in <module>
from pkg_resources import load_entry_point
File "/usr/lib/python3/dist-packages/pkg_resources/__init__.py", line 3243, in <module>
def _initialize_master_working_set():
File "/usr/lib/python3/dist-packages/pkg_resources/__init__.py", line 3226, in _call_aside
f(*args, **kwargs)
File "/usr/lib/python3/dist-packages/pkg_resources/__init__.py", line 3255, in _initialize_master_working_set
working_set = WorkingSet._build_master()
File "/usr/lib/python3/dist-packages/pkg_resources/__init__.py", line 568, in _build_master
ws.require(__requires__)
File "/usr/lib/python3/dist-packages/pkg_resources/__init__.py", line 886, in require
needed = self.resolve(parse_requirements(requirements))
File "/usr/lib/python3/dist-packages/pkg_resources/__init__.py", line 772, in resolve
raise DistributionNotFound(req, requirers)
pkg_resources.DistributionNotFound: The 'sh3001==0.0.1' distribution was not found and is required by the application
